1 - 5 of 5 Posts
howdy gang iam trying to figure out the best way to run my power wire from the battery to the trunk of a 96 mercury cougar anyone have any ideas? thanks
I always kept it separate from RCA's and the speaker wire. Speaker wire on the left, RCA's in the middle, and power on the right. Anywhere wires crossed it was at a 90 degree angle.
Unless you asking specifically about the Couger. I'm sure the seats and carpet can be removed like any other car. Lots of uncomfortable crouching but necessary to route and hide wires.
Dave
i am having issues with the wire from the battery into the cab of the car i had a 93 tbird which is the same car and this car has the modular 4.6 which is wider and can’t figure out where to run it through the firewall that’s my problem thank u
can you drill a hole and put a rubber grommet in? my local auto parts stores sell the grommets pretty cheap.
Dave
Discussion Starter #5
that’s the plan but the 4.6 engine is very wide and leaves little
room might have to go out the fender and back in that way
1 - 5 of 5 Posts
