1 - 16 of 16 Posts
I am building a 3 cu ft enclosure out of 1" MDF tuned to 20 hz. I am looking for suggestions for an amp, either plate or external. Room size is 15 X 20.
Thanks
I almost used one of these in 5.2^3 tuned to 14.5. I was going to run 1 channel of an EP 2500 to power it. Then I could add another one later with the other channel.
Discussion Starter #9
Ryan-T,
That's an interesting idea. I was looking at the Pro amps but finding one that would do 4 ohm mono, at the 1000 watts the sub would take without breaking the bank was difficult. I need to do more research. Thanks for your input.
The problem with using one of those amps is they have no high pass filter. With the tune of 20hz a high pass is a must.
The Buttkicker has a high pass. The graphs show it really starts taking effect at 20Hz, not the 25Hz it is rated for. I think it would work well.
1 - 16 of 16 Posts
