Anamorphic Projection Theaters
49080 Views 67 Replies 20 Participants Last post by  tbase1
This thread is for all members who have Constant Image Height projection, to show off their theatres..
I'm sure there are few out there, so lets have a look (just out of interest) at what your set up is like..
Information like..
Room size..
Screen size (as in width)
Projector..
Lens..
Seating distance etc..
This information will also help those who are contenplating the move to Anamorphic Projection..
A few shots showing your room and front screen, your projector and lens and just two or three screenies to cap it off would be nice..
61 - 68 of 68 Posts
3
JVC HD990 + Panamorph lens with slide and attachment, curved screen 2: 35: 1 to 107 "
amazing images!
amazing images!
Yes, magnificent! Makes me want to join the projector club, right now!
It is correct to point out that in the system are inserted two processri video, a Lumagen and Darbee ;)
I have a Panamorph UH-480 lens and a Panasonic ae8000 projector. I am trying to figure out for a 150" 16x9 image if i am better off putting the projector as close as possible to the screen or leave it on my back wall shelf which is about 19' from the screen.
I am also thinking of making a sled that would allow me to adjust the projector distance...using 2 linear slide 6' long tracks, and 4 bearings. These would run from the rear wall 6' toward the screen, so I could even get a different projector down the road without having to drill more holes in our ceiling. Once the rails are installed I would attach a plate to the bearings and mount a short piece of pipe to suspend the projector a few inches (or use a thick platform). I would then add 4 more bearings and run a pair of 2' long rails running parallel to the screen for mounting the lens. By doing this I could slide the lens out of the way too. The advantage I have now with the lens is I can go from 180" diagonal (scope) without the lens to 195" diagonal (scope) with the lens. Last night i watched Avatar with the lens mounted on a shelf, and I was blown away with the clarity, and the additional 15" of image.
How does this sound...good idea or not?
140" 2.35 Draper .85 gain screen
Panny AX100 720p pj
Panamorph U85 lense
Darbee 5000
Seating distance to first row: 9 ft
Throw distance from pj to screen: 20 ft
Room: (H/W/L) 8'X12'X20'
Hi, I'm new to this forum and just wanted to share my info.
Room: 18'x35'
Screen: 155" diag 2.40 motorized Acoustically Transparent
Projector: Sony VPL-VW1100ES
Anamorphic Scaling: Lumagen Radiance Pro 4k
Seating Distance: 17.5'
Room: 18'x35'
Update: The Projector has been upgraded to a Sony VPL-VW5000ES
  • Like
Reactions: 1
The mighty Sim2 Mico 50 with a Prismasonic H-1000 motorized lense. My screen is a Elite 103" scope.
174499
174500
61 - 68 of 68 Posts
