21 - 40 of 133 Posts
Senior Shackster , Platinum Supporter
Discussion Starter #25
Re: another css 10" build
YES!!
You can see it in the chart 702.188
I'm using some material from parts express, Sonic Barrier 3/4" 3-Layer Damping Material, do I need to count for it on the air space??
Rodny, I think you'll be fine at 2.38 cf, but if you can squeeze another inch or something out of the depth you'd have it covered for sure, plus the volume for the damping material. I'm actually using that too (the leftovers from another project, so I didn't have enough to cover the entire inside). I think the general rule is if its open cell foam you don't need to subtract, but if its closed cell you do. Even open cell would eat up a little volume IMO, so I would maybe account for about half of what you are actually using?
I talked to one of the techs at parts express he said not to worry about the foam taking any space.
It is actually the opposite right? Damping material makes the enclosure seem larger to the driver. Note that closed cell foam should not be used for this.
eyekode, I was thinking the same thing. Although it isn't as free flowing as other materials used to stuff enclosures (ie Polyfill), the open cell must do a little to help. I think its partly to help deaden any resonance or driver/port noise, etc. from echoing inside the box, and partly to help reduce the air speed within the enclosure which gives the driver the perception of a larger box. I believe that for speakers dealing with higher frequencies (shorter wavelengths) it should also help to reduce the effect of standing waves / backwave in the enclosure, but that won't be much of an issue for a sub.
Jeeze, we better watch out, one day Rodny might get this fabrication thing right... :jiggy::rofl:
:yes:
(Kidding, of course - I have no clue how you are able to make those cuts line up. WOW!)
Nice work Rodny!!!
maybe not so complicated 45s but 45s none the less
so is the going to be the red box?
