1 - 7 of 7 Posts
I am looking to build a Home theater Sub, I just want to copy an existing plan. I live in 3/2 house so size is an issue. It will be 80 % home theater use. 20 % music.
I am looking to use a 10inch Sub with a 250 amp plate. Can someone point me to a good design to use. My budget is about 400$.
I am trying to find a design maybe for that peerless XLS 10. Thoughts ?
Thanks
Chris
Thanks
Chris
Chris,
I hate to honk my own horn, but if I were you, I'd look at my Shiva-X2 with a 300W BASH amp. In a 100L box (3.5 cubic feet) it would absolutely destroy that Peerless with a single 4" flared port tuning it to 20-21Hz.
You would have:
$150 for amp
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=300-750&ctab=2#Tabs
$14 for port
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-352
$200 + shipping for Shiva-X2.
http://www.diycable.com/main/product_info.php?cPath=24&products_id=693
Add a sheet of MDF and you are done. It will crush that Peerless like it was a little girly sub.
Kevin Haskins
Exodus Audio
Here is a small design that fits within your budget...
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-760
You can save money by building the enclosure yourself, but probably not a lot of money. It's a sealed box so that should make it simple.
I just recommended you go larger because once you get a taste, you'll want more. I have a 10" sub and I definitely want to go bigger.
1 - 7 of 7 Posts
