1 - 4 of 4 Posts
TO ANYONE THAT HAS HEARD OR KNOWS OF THE Rockville SPG88 8" Inch Passive 400w 8OHMS VERSION
ARE THEY ANY GOOD AS SURROUNDS IN A HOME THEATER ............
A PLAN TO GET A PAIR FOR MY SETUP ,IV GOT A CROWN XLI 800 TO DRIVE THEM WITH AT 200WATTS RMS
MY ? IS WOULD THEY BE GOOD ENOUGH TO BLEND WITH MY PL-28II CENTER AN MY PL-89 tower speaker FRONTS
THEY ARE ALSO BEING DRIVEN BY A SET OF XLI 800 TOO
__________________________________________________________
ANY THOUGHTS OR ADVICE
They are running my 5.1.2 Dolby Atmos system. I'm using 2 as a center channel for a total of 8 speakers. I LOVE them:T
are the two you use as a center,the two behind the tv
an do you know what the speakers internal crossover is at ,my bic PL-28II is at 2000hz which is ok ,do you know what the Rockville SPG88 is , if not thats ok your set up looks good
Yes.
I want to say around 2khz. Someone posted pics of the speaker disassembled. I can't seem to find the pics in Google. Looks like my pics replaced those pics. I can't believe Amazon deleted their pics.
1 - 4 of 4 Posts
