1 - 5 of 5 Posts
This has been mentioned inside another thread but I thought I'd pull it out as a separate feature request to give it slightly more visibility (as there were no further replies in that thread).
The inuke amps provide a PEQ facility and they provide an app you can use to dial it in from a computer. It would be nice if REW could export a filter set in a valid format for that (as per the linked thread).
Are there any plans to add support for this device?
Thanks
Matt
Discussion Starter #5
If you select the DCX2496 in the setting,s of REW ,it will work by hand,very easy if you have linked it to your comp.
are we sure about this? I find that the Q suggested by REW is *much* narrower than apparently implemented by the inuke. I also notice the hover on the EQ screen (when DCX2496 is selected) says Q is in the range 0.1 to 50 whereas the inuke is 0.1 to 15.
1 - 5 of 5 Posts
