So I'm recording a guy on and MXL 990 condenser mic and getting a quality recording. How should I process this to sound like a nice big rich clear "radio" voice sound?
Currently signal chain:
Gate - fast attack, slow release, to cut between phrases and breaths.
EQ - HP around 120Hz, cut about 2 dB around 500Hz (a bit of mud there), Boosting 4.5kHz and 10 kHz a couple db each
Compression - about 6db's of gain reduction at 3:1 ratio with fast attack slow release.
Any tips are appreciated. Using Pro Tools 10. Waves plug-ins.
Instead of a high pass filter give yourself a 4-6db dip at like 400-ish to add to the other lower midrange cut. You're taking the balls out of your track. If there's no other bass tones interfering, then you don't NEED to use a hi pass filter. Also try straight 9AppsShowbox up coping that compressor and pasting it again after with the same settings.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
