Plain ole user
Do you have a specific question?
I was wonderering how you could use it as a spl meter.. When I used a real SPL Meter according to the Pioneer user manual , it said use the test tone and hold the spl meter at ear level at the sweet spot , which sadly enough is almost the center of the room since i have wall to wall couches and recliners.. Set at 78db according to manual.. So I did and my Rear surrounds and right and left surrounds seem a little loud .. So I found tru rta and thought it would work as well by setting up a mic in the same spot as the spl meter but I get different reading.. Oh well maybe I should have asked has anyone used TRUERTA and how they like it .. I am going to play with it more today and I still have the RS SPL meter that I borrowed so will see what happens.. Thanks for any help..
Plain ole user
I never used it as a meter. RTA is used as a relative measurement tool. To use it as a SPL you have to calibate to some reference. The RS is fine to use as a reference for most purposes. I have TrueRTA but frankly, I don't ever use it. REW is a much more useful tool and real time analysis is of limited value.
If I were to use another program other than REW
I would useSpectrum Analizer Pro Live 2009 from pas-products (just google it I can not post the link)
Easy to use and has a lot of features.
Much better than True RTA
Any chance you were facing the front of the room and holding the meter out in front of you?
(partially blocking the sound from the surrounds)
