1 - 10 of 10 Posts
Is there anything wrong with putting tower speakers on the TV stands?
my TV is actually hung on the wall, speakers are mythos one towers. Thinking about getting a 75" media console and placing the towers on top of the console. Cosmetically I think it might look ok, maybe even better than on the ground since my TV is hung a little higher and the speakers will be elevated to almost match the TV
Ideally you want tower speakers away from the wall at least a foot but sometimes that's not possible. Are they rear ported?
Speakers aren't ported and I see no difference in sound weather I push it against the wall or a foot and a half away.
Tweeters on the other hand would be at ear level only if I'm standing. it'll end up being 3 ft or so above the ears 8 - 10 ft away from sitting area.
I would say that is too high...
I agree it's quite high, what is the shelf made of as vibration may be an issue.
It is important to have the tweeters near ear level. The closer to the speaker that you sit, the more important this is. I would also be concerned with the tower not being on a firm surface.
Sounds like this is not very favorable to most, I might scratch it off and get a small cabinet and sleep better at night. :D
I would definitely not recommend having the tweeters that high above seated listening level. I second that, as well as the safety/Isolation of the speakers on a TV Stand... Good luck! Sorry for reiterating what has already been stated, but I do think that you would be sorry you set it up that way.
Sent From My S4 Via HTS App
1 - 10 of 10 Posts
