Status
Not open for further replies.
1 - 1 of 1 Posts
I'm selling my Aperion 7.1 speaker set up. All work great and very clean. Come complete with the grills, original packaging including their velvet bags. You get two fronts, one center, two surrounds, two rear-surrounds and one sub-woofer.
This system is valued at over $2600! Asking $1100. I'm in Nashville, TN.
If you want it shipped it will be at your expense (added to total).
2 Each Front Speakers
Aperion Audio Intimus 533-T
Frequency response: 65Hz to 20KHz
Nominal speaker impedance: 8 ohms
Recommended power: 50-200 watts
Speaker enclosure type: 2-1/2 Way Vented, Video Shielded
Tweeter (diameter): 1"
Woofer (diameter): Dual 5.25"
Dimensions (HxWxD): 38.5" X 9.25" X 10.75"
Weight: 38 pounds each
1 Each Center Channel Speaker
Aperion Audio Intimus 634-VAC
Frequency response: 60hz to 20Khz
Speaker enclosure type: 3-Way Sealed, Video Shielded
Midrange (diameter): 5.25"
Woofer (diameter): Dual 6.5"
Dimensions LR (HxWxD): 8.25" X 25" X 11"
Weight: 39 pounds each
2 Each Surround Rear Dipole/Bipole Speakers
Aperion Audio Intimus 534-SS
Frequency response: 90hz to 8Khz (Bipole)
Frequency response: 60hz to 14Khz (Dipole)
Nominal speaker impedance: 12 ohms
Recommended power: 50-300 watts
Speaker enclosure type: Sealed
Woofer (diameter): 5.25"
Dimensions LR (HxWxD): 10.5" X 14.25" X 6.75"
Weight: 16 pounds each
2 Each Bookshelf Surround Side Speakers
Aperion Audio Intimus 532-LR
Frequency response: 80hz to 20Khz
Recommended power: 50-150 watts
Speaker enclosure type: 2-Way Vented, Video Shielded
Dimensions LR (HxWxD): 11.5" X 7.33" X 8"
Weight: 13 pounds each
1 Each Subwoofer
Aperion Audio Intimus S-10 Powered Subwoofer
Frequency response: 25Hz to 160Hz
Amplifier power output: 200 watts (RMS)
Speaker enclosure type: Vented
Variable crossover range: 40-160hz
Variable phase adjustment: 0 to 180 Degrees
Volume control: Variable
Auto-sensing 3-position power switch
Low & High level inputs & outputs
Woofer diameter: 10"
Dimensions (HxWxD): 17.5" x 13.25" x 19"
Weight: 56 pounds
1 - 1 of 1 Posts
Status
