Apple control via Crestron
2755 Views 1 Reply 2 Participants Last post by  nholmes1
Can I control my Apple TV via Network from my Crestron MP2e.
I have had it setup via IR and its not great slow etc.
Also if I have a running PC with iTunes open can I view my iTunes music movies via crestron
1 - 2 of 2 Posts
Check out autonomic controls for IP control of the original AppleTV but not the second generation, I have used them before and it provides a lot of functionality from the original appletv. If you want to get a more robust and reliable option look into their MMS-2 media server.
You're crestron dealer should be able to program it for you.
1 - 2 of 2 Posts
