Just wanted to see my only ever sticky hit 100!:R
Thanks matrix, the weird thing is that my counter showed 99 when I made that post so I thought mine was #100 but I look at it now and yours was # 100. Im confused:huh:. Any way thanks for the info and the #100!Glad to see I'm good for something. :flex:
True very true but those units can be too large for some rooms and families, they need at times the use of a profesional to service them and also sometimes you have the added expense of a doubler. The do amaze at times with outstanding image. The LCD/DLP models do an admirable job, can cost much less and are both small and easy to own. Very cool pros and cons that makes this all interesting!In 5 pages of secret projectors, no one mentions CRT projectors.
With them, you can vary the sizes even up to 35 feet diagonal.
One can make the color pop or be muted at will.
There are no "bulbs" to go out every 2000 hours (once a year); there are CRT's that last 15,000 hours if you're careless and over 22,000 hours if your careful. Careful in this case means just keep the overall brightness down somewhat.
Very good 8" pjcrt's are less than $1000 and can handle 1280p while very good 9"ers are about $7k and can do 1080p easily. HTH.
7" crt's are under $500 but they are mostly good for 1024x768.
New Guy
I have a Sony XBR WEGA 34in 1080I set and its a beast, big heavy beatiful picture making beast!The same went for CRT HD sets. They had contrast ratios of a million to one, a better color gamut and a very long life span. I have one myself. Unfortunately the shear weight and size of them were too much. A 30" HD CRT weighs more than 100lbs and they just didn't make them any larger than 34"-36". There were some that were slimmer, but the tradition CRT was just too bulky.
I believe I had the same unit (KV-34XBR910) and I found the picture outstanding, especially in 1080i. It eliminated my need to upgrade to a flat screen for the longest time. I finally gave in when I saw the 60" displays especially the Pioneer 141fd which was vanishing quickly. I also agree that CRTs are still the best in some specs.I have a Sony XBR WEGA 34in 1080I set and its a beast, big heavy beatiful picture making beast!
I paid nearly $3000 for it in 2003 and its still going strong and hasnt not been bested by anything I have seen to date.
