1 - 2 of 2 Posts
46f510 thanks for all your help. heres an example. rh21 is listed at 6.9kohms in manual. Once removed the resistor reads 3.9 kohms. the color code on resistor says it should be 3.9 kohms. do I change it to match the manual or do you make sure codes match components? thanks
Plain ole user
Where is this resistor in the circuit and why is the question coming up? Manufacturers make changes all the time and sometmes manuals do not reflect updates or changes in production. With no context, the question is difficult to answer.
1 - 2 of 2 Posts
