Thanks for the help! I wasn't sure what information was useful and needed. I didn't even think about that the amplifier might be an unknown brand, sorry...
I want to use the subwoofer mainly for home theater but I do listen to music also, so it would be needing to be a combination of the two genre. I live in an apartment and don't have a tremendous amount of space for a sub, that was what got me to think the Peerless SLS 10" might work well. I got a hold of some application notes for the driver and there it stated that it would work well in a smaller closed alignment, even as small as 42 liter. Given the space I have available I thought I could make it a little bigger if that would be better but 60 liters is about the maximum volume I have room for.
I found the driver in WinISD, but found myself a little overwhelmed by all of the unfamiliar terminology. All in all from what I saw in WinISD it could work well, but wanted to get help to have more trained eyes give pointers and others aspects that I might have (most likely have
) missed. Thanks again!
Driver: Peerless SLS 10" P830668 (Is in WinISD)
T-S Parameters
Resonance Frequency fs 33.3 Hz
Mechanical Q factor Qms 4.85
Electrical Q factor Qes 0.57
Total Q factor Qts 0.51
Force factor Bl 10.2 Tm
Mechanical resistance Rms 2.2 Kg/s
Moving mass Mms 51.1 g
Suspension compliance Cms 0.45 mm/N
Effective cone diameter D 20.7 cm
Effective piston area Sd 335 cm2
Equivalent volume Vas 69.3 ltrs
Sensitivity (2.83V/1m) 88.7 dB
Ratio BL/√(Re) 4.3
Ratio fs/Qts F 65
Amplifier: Zachry DSW-150
Rating: 120W at 4Ohm/70W at 8 Ohm
Crossover: 40-180Hz
Phase Adjustment: 0/180°
Lowpass filter: RCA
Highpass filter: Yes
