21 - 25 of 25 Posts
REW Author
The plots all look fine, I'd say just go ahead and make measurements and don't worry about the meters. The soundcard response is flat enough and extends low enough that you don't need a cal file.
Huh, that's the first time I've seen this happen. The soundcard.cal file is fine, and all appears to be working great except the meters aren't working. Weird.
You'll have to use the scope as a check on your input level (in lieu of the input meter). The dark red is the input. Be sure it doesn't clip. If it does, turn down the input a bit and remeasure....
Discussion Starter #25
Thanks to you both; will work some more tonight and next few day and will let you know how it goes.
I know the drivers are more like Release Candidates then finals and I suspect they still need tweaking. They should have some new ones in the near future which hopefully will correct this.
Rew
21 - 25 of 25 Posts
