what im really looking for as comparion is data measurements like port vrms output for the xlrs an sinad ratios an values like the kind ya'd get on audiosciencereview.com
i know the outlaws as the 976s is got some details on ther main that the at300 does not like this
Analog Section
Input Impedance
47Kohms Output Impedance
(Main-RCA)1KOhms Pre Out
RCA 4Vpk; XLR 9Vpk Frequency Response
Line 10Hz to 80kHz ± 1dB S/N Ratio (IHF-A)
112dB Volume Range (Main)
-90dB to +0.0dB Bass Management
Crossover Frequencies
Adjustable 40-150Hz in 10hz steps, + 200Hz High-Pass Slope
(Small Speaker Setting) 12 dB/octave (2nd order) Low-Pass Slope
(Subwoofer) 24 dB/octave (4th order), Tone Control
Bass Center Frequency/Range
100Hz ± 10dB Treble Center Frequency/Range
10KHz ± 10db Tuner
FM Tuner Section
Sensitivity
IHF 10dBu typ.
50dB S/N 13dBu typ. S/N Ratio
Mono
70dB Stereo
67dB Distortion
Mono
0.2% Stereo
0.3% Stereo Separation
40dB typ. Adjacent Channel Selectivity
70dB +/- 400kHz IF Rejection Ratio
120dB Frequency Response
20 Hz to 15 kHz ± 1.5dB AM Tuner Section
Sensitivity
(20dB S/N) 300uV S/N
45dB Selectivity
25dB Distortion
0.7% Digital Audio
Digital Audio Inputs
75 ohms , 0.5Vp-p Processor
TI-DA808 General
Supply Voltage
120V +/-10%, 60Hz only Standby Power Off :
0 .5W Trigger Output
Sequential Delay 50 mA @ 5VDC Dimensions
(HxWxD)
4 5/8”x17”x11” Weight
12 lbs.
if anyones got those data details on the at300 sinad output db an other values an any screen shots of the manuel id like to read over to compare to the outlaws these pages were helpful to me in my chose to by it an with similar detail of the at300 would do the same for it
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
