1 - 5 of 5 Posts
Im currently researching DIY AT screen and would like to give it a shot. My primary concern regarding the screen is my subwoofers. I have four 10" subwoofers built into the front wall where the screen is placed. The subwoofers are on either side of the screen right now, but if I build a new screen, it would be much larger and would cover the subwoofers.
How much physical vibration should I notice through the screen if any? Obviously, none if I can help it.
The subwoofers would be pretty close to the screen (2"away best guess).
I guess it would depend on how tight the screen is. I asked the same question a year ago and was assured by someone that it wouldn't be an issue. I have 3 M1's from Chase ( I know its not the same as 10 subs) right behind the screen and it doesn't cause issues
i have a infinate baffle speaker manifold just to lower right of screen. I have not had any issues with screen vibrations or ripples during a movie.
I will let you know how mine goes in a couple of weeks... I have the Danley DTS-10 firing up in front of the screen, about 6" away.
Well if the Danley doesn't move the screen I do not think most of us would have an issue. Keep us updated in case my wife lets me change things up someday
1 - 5 of 5 Posts
