SpeakerHobby.com is proud to announce the distributorship of Audience's new A3 "true" full range loudspeaker driver!
Audience is the company that builds the AuriCap high end capacitors and have other lines of fine audio products as well.
I met the owner and we talked about making this driver they use in their speaker systems available to the DIY market.
Do you want to build a full range loudspeaker without a crossover? Then this is the driver to use!
Crossovers seem to be one of the DIY'ers most difficult task to handle when building a 2, 3, or 4 way system. I know this first hand because I've been building loudspeakers for over 14 years. The lack of a crossover eliminates the resistance of the components used in the crossovers and potential mistakes in the crossover's design. This allows the drivers to perform to their full potential.
The A3 3" driver has a usable xmax of 12 mm p-p and a mechanical xmax of 15. This is one of the most versatile drivers available to date. Presently being offered with a 16 ohm voice coil, you will parallel two drivers for an 8 ohm load. You can use a pair of these drivers for your home theater center, side surrounds, and center back speakers. Build them into your wall between the studs, in the ceilings, or even install a pair of them in the wall cavities on each side of your boat's main salon or staterooms!
Series and parallel the drivers to get the desired ohms you want to present to your amplifier and simply choose how large you want to build yours; 4, 8, 16 or 24 driver line arrays!
The 3 inch Audience A3 driver cones are made of an aluminum magnesium composite. The total moving mass of each driver is 2.5 grams, and with a massively oversized motor structure they are exceedingly fast and exhibit rise times similar to electrostatic loudspeakers resulting in ultra high resolution sound reproduction. The drawback with electrostatic loudspeakers is that while very defined they have limited dynamic range. The Audience A3 drivers, drivers being dynamic drivers provide the best of both worlds; high resolution plus dynamics. The 8 driver system, for example, can play at 123db continuous at distortion levels that one would normally associated with quality amplifiers. The result is stunning high resolution distortion free reproduction of sound.
The Audience A3 is a breakthrough full range loudspeaker driver design comprised of a patented motor structure, patent-pending suspension and patent pending basket. The A3 has an exceptionally flat response from 40Hz to 22Khz, and -20 at 20Hz with very high power handling and dynamic range. The A3 is built like a high power sub woofer driver using a large neodymium motor structure, big voice coil and suspension venting. The A3 is ultra responsive at 2.5 grams total moving mass providing state of the art resolution and dynamic range. The A3 sports 12mm of usable excursion with less than 1 dB compression at levels up to 95 dB SPL.
I've provided a couple of videos from the 2008 CES (Consumer Electronics Show) in Las Vegas.
The first clip is an interview with John McDonald, the owner of the company describing some of his background, Audience, and the direction Audience is headed:
http://live.audiogon.com/events/the2008/vids/Audience_intv.html
The second clip has Roger Sheker, the chief engineer describing the 8 driver loudspeaker design they sell.
http://live.audiogon.com/events/the2008/vids/Audience_tech2.html
Roger explains that the speaker in the video is capable of 70hz on the low end. These are their ClairAudient line source array speakers but they are using their previous driver, the Bandor. The new A3 drivers will get you down to a flat response of 40 hz and -20 at 20Hz.
The list price for the A3 full range driver is $170 ea. For 8 or more drivers, I can discount them to $150 ea. Orders for 4 or more drivers, I will pay for your shipping to the lower 48 states.
Here is a link to the specifications of this fantastic loudspeaker driver:
http://www.speakerhobby.com/A3StatsGraph.pdf
Please visit my website for ordering information and find some useful tips on how to build your cabinets using the A3 drivers. More information will be added about the A3 driver, and updates on upcoming drivers with different voice coil configurations will be added as soon as they become available.
Thank you,
Mike
http://www.SpeakerHobby.com
Thank you,
Mike
