Hi all,
A while ago I purchased a Behringer UCA202 that turned out to be fake ( eBay).
I tried to use it with my DIY jig (using two 5 ohm non-inductive resistors in series) and I could not get the thing to work without noise.
Eventually, I went to a friend to use his Dayton DATs to get out the T/s specs.
Since then I kind of dropped the whole thing altogether, But I still want the fun of doing the measurements at home.
What is a fairly good and non-expensive audio interface I can use to do impedance measurements?
I was looking at the Behringer UMC202HD - would this be sufficient?
I've got a Macbook Pro running macOS as well as Windows 10 so drivers should not be an issue.
Thanks,
David
That is a fairly low resistance value, many soundcards would struggle to properly drive the overall load unless they had a decent headphone output and you used that. The unit you mentioned may well fit the bill for that but I don't have any experience of it. Steinberg's UR22 MkII is very good but quite a bit more expensive.
I was using the headphone output on the UCA202 to power the driver.
Only reason I used the 10ohm load was because I read it was best to use non inductive resistors.
I can replace it with a standard 100ohm 1/2w resistor, but will that be sufficient?
The UR22 looks like a good piece of hardware but its way over my budget.
I think I'll pull the trigger on the UCM and see what it's worth.
As for amplification - I have a bunch on single rail TDA2030 amps laying around - would using one of them be good enough for a few watts of power? They are china kits and have a 470uf decoupling cap on the output but might be a tad noisy, unless I would be okay with running off the line out of the sound card (UCM)
It might be worth converting to dual rail for better response.
Running through an amp can work well, but if it has gain probably best using some dividers to protect the inputs of the soundcard.
I can alter the gain of the TDA2030 to keep it fairly low. But I do plan to add a divider to the inputs of the sound card anyway if using an external amp.
How are you running the circuit on the UR22? I assume you are running unbalanced input/output via TRS?
Do I need 2 ring plugs(+/-/ground) on the input or can I use a single ring plug (+/ground)? I don't want to short anything out.
I haven't used the UR22 for impedance measurement. I've used single ring (TS) plugs on the UR22 inputs in its combination sockets without any issues.
