1 - 3 of 3 Posts
Hi all,
Anyone know of any issues with REW 5.01 Beta 19 Linux 14.04 that cause an inconsistent output?
It pulses on and off.
Cheers,
Andy
:help:
Discussion Starter #2 (Edited)
OK - I solved it. It involved some Red Wine, Pink Floyd and lateral thinking.
Do not use the OpenJDKRuntime thingy available from the Ubuntu Software Centre.
Instead, use full blown Java v7
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java7-installer
Then
sudo apt-get install oracle-java7-set-default
I uninstalled the OpenJDK, and boom!
I thank you.
A
Thanks to webupd8.org for the instructions!
The problem I had (REW 5.12, Ubuntu Linux 14.04 LTS) was simply nowt out! Nothing from the generator, either on the meters nor the physical output, no clicks, nothing to anywhere (speakers, headphones, external soundcard, PulseAudio, default, Codec...). And no error messages. But the input department appeared to be working fine.
Solved as above by removing Open JDK Java 6 & 7 runtimes and substituting the full-blown Oracle Java 8 instead.
Thanks andywardle & webupd8.org
1 - 3 of 3 Posts
