Hi all, I'm an audio enginner, software developer (and gamer by heart).
I've been thinking about designing an affordable high quality single channel dedicated DSP for podcast & streaming so that your mic reaches your computer at an optimal quality with easy setup, controllable via android and iOS apps and tons of presets from audio engineers and streamers and third party developers.
The processing chain would have a range of high quality compression, limiting, eq, exciters, de-essing, parallel and multiband processing and noise reduction algorithms.
It would support usb mics and headsets, but it would also have its own mic pre (XLR) and the output would be usb to the pc. Near zero latency added to the signal path, and, since it's an outboard processor, it would not demand any extra CPU usage to your PC.
Is this something you would be interested in or is there anything else you would like to add to it?
If not, why? And what is your current audio setup?
Cheers.
