1 - 4 of 4 Posts
So I know there are a lot of plate amp options but I am looking for a cheap but ok plate amp to power a old sub that I have had for a few years and the amp is now deceased with the last words of a constant 60hz hum at 200 watts. Im guessing that the power supply went bad with what I think is a short to ground in the supply. Anyway, is it worth throwing money at?
Is the sub worth throwing money at?
Which sub is it?
How old is it?
If you were to replace it how much can you spend?
When it was working were you satisfied with it or was it just OK?
Discussion Starter #4
I think it might be time to send it to a waste management site. It would be OK for someone that just needs a little low end. Time to ask some friends I guess.
1 - 4 of 4 Posts
