1 - 4 of 4 Posts
hi shacksters
I seem to have a timing problem on the audio on my setup, I see the caracters speaking on the tv then a second or so later I hear them ( no this is not a translated show, it does it on every thing I watch)
all the audio betewn the different components are plugged with toslink optical cables
my setup consists of a 36" samsug lcd, samsung avr720 receiver, Lg dvd recorder, illico cable box
I never had a timing problem before, or I never noticed it before.
has any of you had this king of problem before?
any help will be apreciated:help:
thanks in advance
FRED
This is a common problem, its called lip sync delay particularly with satellite and cable. Does your receiver have an adjustment in its menu for lip sync?
thanks for the quick reply (I'm the slow one :bigsmile:)
no I can't find any adjustements for it
it's weird, it only does it on certain channels.:dontknow:
I guess I'll keep looking
thanks for the help
FRED
1 - 4 of 4 Posts
