1 - 5 of 5 Posts
I ran across this today and was wondering if anyone had any experience using these to tame room response in their home theater. I know I can make some DIY panels but since I am nearing the end of a full year of home improvements, I just want an inexpensive readymade solution that will work. Any help would be appreciated.
That is a **** of a good buy. Foam doesn't work as well as fiberglass or rockwool, but you can always double up the foam at that price.
Thanks for the info, I may just have to hit my ceiling with these.
The great thing is there's also space and attachment points in that configuration to insert a limp-mass membrane to hopefully absorb more bass energy.
1 - 5 of 5 Posts
