1 - 2 of 2 Posts
I have Apple TV (generation) connected to a Ricoh PJ X2240 projector and I am looking for a solution so the projector automatically turns on when I activate the Apple TV.
I did some basic research and didn't find any way to update the HDMI-CEC / infrared settings on the Ricoh PJ X2240.
The goal is to simply use the Apple TV remote to turn on both at the same time.
I'm open to any suggestions.
Super Moderator
Your best bet will be a universal remote that has head-to-head learning (which will only work if you have an IR remote for the projector.
You have another potential issue as well. Assuming the projector is overhead and the Apple TV is at the front of the room near the TV, you will need an IR repeater to bet the signal to the projector, assuming you don’t want to have to aim at each unit separately.
1 - 2 of 2 Posts
