Yamaha, NAD, Onkyo (Integra), all very good brands. I own them all. Pre-pro.Hi All,
I am looking for suggestions for Preamp/Processors.
Bdget 1K or less.
I woild also be interested in Receivers with pre outs for LCR
Thanks.
Well, if you shop around you will find a good one for $1499. That is as inexpensive as you will find.Thanks. Seems like 1K processors do not exist. Might havd to stick with a receiver with the pre out option.
I have been wondering what a Pre-Pro does exactly ? My gear is listed below. Do I need to invest in one ? Thank you.Yamaha, NAD, Onkyo (Integra), all very good brands. I own them all. Pre-pro.
You might try Audiogon, and/or Ebay. Or even Craigslist.Seems like 1K processors do not exist. ?
This home theater or AV receiver works an ideal AV pre-processor on the new Pre-Amplifier Mode. It functions perfectly with the most advanced HDMI connectivity. The Pre-Amplifier Mode disconnects internal amplifiers to offer a cleaner signal path and improved tolerance in the clipping level.Denon 3700 can be had for under $1000 USD. Denon's in this series have excellent pre-out signal quality unlike most ALL other AVR's (see Audio Science Review and Audioholics tests), and can be used as a true pre-pro as you can all internal amps off (or just L/R and use the built-in amps for surrounds etc.).
Yes, like do you want a full surround with Dolby Atmos 11.2?We need context. How many speakers? Which ones do you want to amp?
I actually have an Anthem MRX 720 thats about 4 months old that I would be willing to sell if you are interested. I am looking to pick up a Krell setup so am going to sell this Receiver. I also have an older Denon AVR 6200w that I have here in another room as well I am sure we can work out some price. I am in the SF Bay Area.Hi All,
Bdget 1K or less.
Thanks.
