Status
Not open for further replies.
1 - 1 of 1 Posts
how does a beautiful cabinet with a serious 12" driver and 1000Watts of power and will give you low teens in room for $600sound?
12" driver 3" voice coil 50 mm vented pole piece Multi-layer Kevlar impregnated honeycomb cone for extreme rigidity Hand-stitched Santoprene rubber surround Dual mirrored spiders with opposing silver plated cadmium copper tinsel leads
UFW-12 sub cabinets built by Sound Art China for AV123 years ago. These are the good cabinets without all the veneer problems that plagued av123 after they moved production from SAC.
Amp is brand new and has been customized by Motor City Custom Audio and Seaton Sound. The new amp has had the limiter adjusted and a notch filter along with a high pass that has been fixed that results in this amp playing down to 23hz and with room gain should get you to the low teens in all but the most open rooms.
You can pound on this thing and it will make no funny noises!!
As you can see from the graphs it(red) kicks the snot out of the original ufw-12(green) from av123. Also shown in the graph is the 15" version(blue) that I can upgrade the sub to, this will get you a little deeper response and a bunch more SPL.
Shown is Piano Birds Eye Maple... rosewood, Madagascar Ebony and piano black are also available.
I have some new gear I need to get so I am taking offers
$600.00 OBO and I will warranty the amp and driver for 1yr....
If you already own a UFW and would like your amp modified please contact me
1 - 1 of 1 Posts
Status
