Hi,
I'm looking to build a ported 15" subwoofer built into an endtable. A reasonable size end table will get me about 6 cubic feet of internal volume before vent, driver, and brace volume. I'd like it tuned around 20hz, the lower the better, i think.
I will be using it for 70% home theater 30% music, but music performance is important to me. I plan to power it with either an EP1500 or EP2500. It is going into a room of about 2500 cubic feet, although the room is mostly open to the rest of the first floor.
I plan to build two identical end tables but only use one as a subwoofer at this time. Wiould an EP1500 be enough to drive two of these subs in the future?
So which driver do you think would be the best? Based on my research it seems as though the AV15H would be the best as it seems to work well in small boxes and has excellent SQ and midbass. Thoughts? All are about the same price.
Also where can I find info about sizing the port correctly? Whether it be a slot port or tubular.
Thanks,
John
Thanks,
John
