AV15X sub and Behringer DSP1124P
1626 Views 4 Replies 3 Participants Last post by  Rightbrained
4
SOLD
Since I have moved to a horn loaded sub I dont have a use for these anymore.
This is the AV15X from Acoustic Elegance made to order in the USA.
I also have a Behringher DSP1124P to go along with the sub. I have removed the rack ears.
$250.00 plus shipping and paypal fees takes both the woofer and the eq.
Photos and specs below.
DSP1124P photos.
AV15-X - 4 ohm
Fs: 24Hz
Qms: 4.1
Vas: 197L
Cms: .22mm/N
Mms: 200g
Rms: 7.4kg/s
Xmax: 23mm
Sd: 794sqcm
Qes: .39
Re: 3.2
Le: .196mH
Z: 4ohm
Bl: 15.6Tm
Pe: 1000W
Qts: .36
1W SPL: 90.4dB
2.83V: 94.3dB
Status
Not open for further replies.
1 - 5 of 5 Posts
nice sub,wish you had two,or I would have picked this up from you
on a side note what exactly does the feedback destroyer do again
The feedback destroyer is used as a parametric eq.
I did have 2 of these but have already sold one.
1 - 5 of 5 Posts
Status
