1 - 13 of 13 Posts
Eventually I'll build my 20 cubic foot LLT. But for now, I want to build a sealed box for my avalanche 18. It'll be run with an EP2500 and a feedback destroyer pro. It'll be used for 80% movies, 10% games, and 10% music. How big should I make it? Right now I'm thinking about a 2' cube. That should net around 7 cubic feet after displacement and bracing. I have two velodyne 10's now.
Super Moderator
24" cube is about 6.5cuft with only 3/4" walls. I usually double up on walls and then add some bracing which would put me closure at 5cuft net after driver.
I was thinking single wall, double baffle, with bracing. 24" sound nice because it would only take one sheet.
Super Moderator
Well brace very well as 15/18's can definitely flex walls.
Super Moderator
15/18's??
edit: You meant 15's and 18's. I'm a little slow today.
Ya sorry about that. I know you are using an 18 but I just wanted to say that even a 15 can flex the walls a bit.
Discussion Starter #7
I'm also debating being lazy and buying a mini Marty flat pack. Because if that's enough, I don't have to build the huge LLT I had planned. Where as I don't know if the sealed box will have enough low end.
Super Moderator
Is that the 3.5cuft tuned to 17hz?
For some reason the pic isn't showing up on my phone.
MiniMarty 2' by 30" by 36" ~17hz tuning in 10cuft
Or
MiniMarty 2' by 2' by 40" ~17hz tuning in 9cuft box
Here's a link to the for sale thread
http://www.avsforum.com/forum/209-audio-gear/1529375-martysub-flatpacks-veneer-flatpacks.html
I'm building myself a Mini Marty (so I can make it downfiring w/ legs) myself using a 15" SI D2.
The guys on AVS make some good flatpacks. IIRC there is another guy making a flatpack thats more shallow and vents off to the side and looks to be good. Also meant for 15 - 18" subs...
Discussion Starter #13
1 - 13 of 13 Posts
