One have quad 1 ohm vc the other have dual 2 ohm vc. Which one is better and why? Thanks!
F f155mph · Registered Joined Oct 1, 2008 · 28 Posts Discussion Starter • #1 • Nov 4, 2009 One have quad 1 ohm vc the other have dual 2 ohm vc. Which one is better and why? Thanks!
M Mike P. · Premium Member Joined Apr 6, 2007 · 19,397 Posts #2 • Nov 4, 2009 Those are different coil configurations for car audio. Which one is better depends on what final load (ohms) you want for a specific amplifier.
F f155mph · Registered Joined Oct 1, 2008 · 28 Posts Discussion Starter • #3 • Nov 4, 2009 I asked because they both seem to wire up the the same. Either 1 ohm or 4 ohm.
M Mike P. · Premium Member Joined Apr 6, 2007 · 19,397 Posts #4 • Nov 5, 2009 A quad 1 ohm can also be wired for two sets of .5 ohm coils and run by two .5 ohm stable amps.
