Receiver:
Yamaha RX-V480
220 Watts Total
Television:
1x Mitsubishi VS-4551
45" @ 4:3 Screen Ratio
Center Speaker
1x Polk Audio CSi25
100 Watts RMS
Front Speakers:
2x Polk Audio R50
150 Watts RMS
Surround Speakers
2x Sony SS-U4030
100 Watts RMS
Subwoofer:
1x KLH E-12DBN (Subwoofer)
125 Watts RMS
Acoustic Research 18 ga. Performance Series Speaker Wire
100 Ft. Length Roll
Sources:
Sony Playstation 2 SCPH-70000
Nintendo Gamecube DOL-001
Nintendo 64
Super Nintendo Entertainment System
Microsoft XBox360
Phillips DVP642/37
I want a more powerful Receiver, but don't know which brand to choose.
Receiver:
Yamaha RX-V480
220 Watts Total
Depending on your budget ... here is some options:
Yamaha RX-V663 ... Onkyo 805 ... Onkyo 606 ... then you also have Pioneer, Denon, Marantz and others that might be out of your budget (BTW I don't know what it is...)
You already own a Yamaha, so you know their quality and Onkyo is the best bang for the buck according to people who bought them :yes:
This AVR's have the TrueHd and DTS HD decoders ... so, if you plan to get a BluRay in the future, you don't need to upgrade the AVR ... you can upgrade the speakers little by little :T
100 Ft. Length Roll
You will need to go with larger gauge speaker wire, minimum 16awg and I always recommend 14awg. dont get taken by the expensive wire Home depot speaker wire is just as good as Monster wire.
As David already said Onkyo, Marantz Yamaha HK and Denon all have good receivers. What is you budget?
Discussion Starter #6
Heh, I have made a decent amount of upgrades this past 2 weeks. Now got some new equipment. :D
Receiver:
Onkyo TX-SR 876
980 Watts Total Power
Television:
1x Panasonic TH-46PZ80U
46" @ 16:9 Screen Ratio
Center Speaker
1x Polk Audio CSi25
100 Watts RMS
Front Speakers:
2x Polk Audio R50
150 Watts RMS
Surround Speakers
2x Sony SS-U4030
100 Watts RMS
Subwoofer:
125 Watts RMS
100 Ft. Length Roll
Sources:
Nintendo 64
Microsoft X-Box360
Phillips DVP642/37
My next upgrade will be the Center Channel, Rear Speakers or Sub. Once I do one of those, I will upgrade my Speaker wire to either 12 or 14 gauge speaker wire.
