1 - 3 of 3 Posts
Banana Plugs: Closed Screw Type vs Open Screw Type? I ordered the open screw type of banana plugs by mistake. Should I returned them for the closed screw type? What is the audio or performance difference?
There should be very little difference between the two.
I use gold plated open ones myself only because that is what the local store had in stock at the time.
I agree. As long as you have a solid connection that won't come loose you are fine.
1 - 3 of 3 Posts
