1 - 20 of 46 Posts
Hello all. For a while now I've been picking away at my new theatre. It's not really dedicated, but the main purpose of the room will be for movies and games. The dimensions are 11' x 22' x <8' . The area by the "screen" is 4' wider. I might put a shelf or counter along that wall where the current shelves are for snacks or what-not. Haven't gone that far into the planning. What I do have planned is change out the seating once carpet it complete. Might do a sectional; one that is small enough to allow people to walk by. The back end of the room, opposite of the screen, will be where a table will sit, mainly for my cards nights. AV rack will tuck into the corner to get it out of the way as much as possible. I might get rid of the rack and build something else to house the equipment...and make it muli-functional. Behind the current seating, I want to put a bar height counter, about 4-5 feet long, with bar stools. This counter would be attached to the wall jutting out, to separate the cards area to the rest of the room. The ceiling is planned to be drywall on resilient channel. I am currently putting in 2 layers of roxul safe n sound in the ceiling. Since our present economy isn't the strongest, I'll be taking my time doing the next phase of construction. At least the permits are done and no longer on a time restraint.
Current equipment:
Epson 3500
Onkyo 706
Emotiva xpa 3 and 5
Xbox one, ps3, ps4, Wii U
Paradigm monitor 9 v4
Cc 290 v5
Adp 170 v4
Adp 370 v4
PS 1000 v4 (x2), and v3 (x1)
I am currently working on obtaining one more v3.
The screen I have up now is a piece of painted mdf. Final screen size will be a big larger, but most likely won't go over 120".
The rear 4 pot lights are dimmable via remote, and I'll have a pendant light on a separate switch for above the card table.
I need some recommendations for a ceiling mount for the projector! Any other ideas or comments would greatly be appreciated.
Discussion Starter · #2 ·
In the middle photo where you see a ladder is where my future bathroom will be. That project will be a doozy. Lots of ideas!
Finished resi channel and got some drywall up.
Got the epson universal ceiling mount and had to add a 2-1/2" threaded nipple to lower the projector so I wouldn't have to use keystone correction.
Have some vibration when people upstairs are walking around since I screwed the mount in the joists. I think I might rig up some sort of rubber dampers and see if that helps.
Before you get the drywall finished, drop it at the projector location. Span the width distance with a couple laminated 2x6's and fasten them to your walls. This will provide isolation from your ceiling/floor joists deflecting from above and keep the projector more stable.
It's too late. All ceiling drywall is up and I'm not gonna drop it. Lets hope isolators will help. At least I don't have a heard of elephants constantly running above.
It's been a while since the last post but I have come a long way, even with only being able to work at it for an hour or two now and then. Everyone love pictures so here's a bunch to show progress.
I have Jaws on order and waiting for the call to pick it up anytime now. It will be going beside the BTTF poster. Those two are in the stairway to the basement, and the Alien is at the bottom of the stairs, on the way to the movie room.
I didn't take any pics tonight but I'm now doing the last coat of mud. I hope to be painting soon.
Sent from my SM-G870W using Tapatalk
Looks great, congrats. I am also using Paradigm speakers in my HT and noticed you have the ADP's. I found they work great placed next to the main listening position as side surrounds as well as diagonally in the rear corners as back surrounds. I made some changes recently while upgrading to an immersive setup for Atmos and Auro-3D and am now using the ADP's as wide channels. The ADP's sound excellent as wide channels which are used in Atmos, the Audyssey DSX upmixer and the DTS-Neo X upmixer. Your room may not accommodate wide channels but height channels should be no problem. Any of the small Paradigm Cinema series speakers would work fine installed high on the walls or on the ceiling. Have you considered upgrading your receiver to take advantage of the new immersive formats?
Here are a few to consider:
http://www.accessories4less.com/mak...twork-receiver-wi-fi/bluetooth/airplay/1.html
http://www.onkyousa.com/Products/model.php?m=TX-NR646&class=Receiver&source=prodClass
I have considered, and both of those were on the list. I am leaving towards a Marantz for an upgrade, but at this point I won't be going Atmos or similar format. Too bad I live in Canada cause that's a sweet price from accessories4less.
I use the Marantz 7702 processor and am very happy. Better to finish your build this year and wait to see what the new models receivers for 2017 will be after October.
The only other idea you may want to consider for now is a power conditioner (not a power strip).
Here are a few links. I like changing the wall socket first, the power conditioner next and finally the power cords. Check out the article on the three pillars of a good system and Auro 3D:
http://mrgcustom.com/press/Electronic House Jan 2016 Issue - MRG Theater.pdf
and then here are a few links.
http://hometheaterreview.com/ac-power-product-reviews/
http://shop.mapleshadestore.com/Power-Conditioning/departments/253/
The new gear I get for this room will be this year, and will be kept for at least 5 years. Don't plan on upgrading any more for this house. I just don't see a point. But I want wifi, preouts, and at least 7.2. On board power not required.
I would still wait to get equipment until the room is finished... I was told this, and didn't listen. My theater was semi finished in July 2014, and I am enjoying it so much that it hasn't been finished yet. I wish i had listened to others and not put the equipment in the room until it was finished. Your room looks great! I am in the same situation as you with footfalls...please post up what you do to eliminate the problem.
Discussion Starter · #14 ·
It won't be for a while before I solve that problem since the projector won't be going in until after paint. Gonna be a bit since it's taking me forever. Well, so it seems.
Finished painting the room; still have to do the stairway, but different colours. Completed subfloor! Probably the easiest part of the whole project, and most expensive. About $600 CND.
Doors have arrived and I might tackle that job tonight. Hollow core for the utility room and a solid core for the theatre.
Discussion Starter · #18 ·
Finally built a frame and used Elite Screens DIY material. Cinewhite, 1.1. Total size 110" diagonal.
Discussion Starter · #20 ·
Thank you and I really appreciate the comment.
Im still debating on putting wood or stone on the ledge below the posters. Same in the theatre room along the left side as there is a long ledge.
I haven't found a solution for the projector vibrations from people walking above. It was mentioned before I and believe the best decision is to have beam in the ceiling that isn't attached to the joists or upper floor. Basically suspends from wall to wall, and the projector mounts to the beam. Oh well, too late for me to do that now.
1 - 20 of 46 Posts
