1 - 3 of 3 Posts
Placing a wall unit for 65" tv ...
Ceiling soffit is somewhat not centered where I believe the center of tv would go..
Q. Does the ceiling soffit thus dictate I must center the wall unit under soffit?
I.e. is it going to look unbalanced if it is 3 foot off center?
Thank you....
Sent from my SM-G960U using Tapatalk
Left-right symmetry is very advantageous for sound quality. Front-back symmetry is helpful especially if openings into the room are involved. I would suggest absorbent materials on both vertical sides of the soffit... acoustic foam or fabric similar to a comforter (some loft and absorbent properties. And if the low point in the soffit is left-right, consider some absorbent materials to make the reflective points in be in the center of the room/soffit. You can use a mirror to see how first reflections reach the main seats and use absorbent materials so that both ears receive sound that's relatively balanced.
1 - 3 of 3 Posts
