1 - 20 of 24 Posts
Im finishing my basement. Framing is done, and im getting quotes on the electrical. My dilemma is this. I was going to put a 36" TV in the media room with a drop down 100" screen. Then i was like "screw it" no TV just the projector in the media room with the components in the rear of the room.
Now I KNOW it will be a while before i can afford to get the projector, screen and surround i want, so i will have a TV in the room for a while.
Question: Is it crazy or feasible, to have the electrician to wire the room for all the components at both ends of the room? So once i get the projector i can move all the components to the rear of the room and placed into a cabinet.
Im new to the theater thing. Ive seen the cable plates on the walls and have no idea what goes to what, so i would love some insight on what i need to do here. I will post pics when they take the "newbie" tag off me !!
THe room is 16' w x 25'-8"
I wouldnt mind a built in closet, but one wall is is an exterior wall one is a load bearing wall one is a concrete foundation wall and the last one is the other side of a soon to be bedroom wall.
COME ON BABY!!! Break is down for me dawg. I assume you mean conduit wire? I was hoping it didn’t sound crazy. I’m just trying to think ahead. I may not always want the components up front which are why I wanted the room wired for them to be located either front or back. And once I get the projector, I probably wont use the TV and unless im watching 2 games at once, i would just assume remove it and watch the projector.
Also i have heard guys say they run future wires through pipe so they can get to it or add to it later. How is that done and how do they access it?
I am an umpire/official in my spare time, so im paying for all this outa my pocket and not taking out a loan. I can’t afford to get screwed by any contractor so I need to know what im talkin' bout just so the contractor’s dont think they have a dumb but on tha hook.
Pipe is what conduit is. Just a path before you close up the walls and ceiling to be able to fish wires later. Just run 2 sets - 1 set from where you have equipment, speakers, sub, TV, PJ now - and 1 set for how it would be later after the PJ and the equipment move, though the speaker locations won't change.
Bryan
· Super Moderator
Welcome to the Forum, Gripp! You might want to use our post padding thread to rack up the number of posts you need in order to upload some pictures.
An electrician is fine for your lighting and electrical, but don’t assume that he will know anything about component video, HDMI, etc. Basically, you will need to determine what kind of wiring needs to be run where ahead of time, and probably have it on site for him as well.
So no sound system either, just a TV? Maybe you should put the project on hold until you acquire at least most of the equipment you’ll need.
But here’s a brief run-down of what you’ll need.
  • A dedicated electrical circuit for the HT gear, with plenty of outlets at the equipment location, an outlet at the projector and an outlet at the location where you anticipate the subwoofer to be. Have the subwoofer and projector outlets fed back to the equipment location, so they can be set up to receive power when the system is turned on.
  • A separate circuit for the theater lighting and other wall outlets, on the opposite phase from the dedicated HT circuit.
  • Coaxial cable feeds (RG-6) to the equipment location for CATV, satellite, OTA antenna, or whatever you intend to get your TV programming. Also, a phone line feed, and a feed for an outboard FM antenna, if that is needed.
  • Speaker wire run from the equipment location to the speaker locations. In-wall rated CL-2 or -3 cable. You’ll need to know ahead of time if your rear speakers are going to be hanging on the wall, or sitting on the floor (the former is preferred).
  • Video cable feed between the equipment location and the projector location. Decide if you want it to be component video or HDMI.
That’s all that comes to mind – perhaps others can chime in.
Discussion Starter · #6 · (Edited)
This is the final layout Im looking for. Due to have hvac duct put in soon. My floor joist above have a 12" oval cut out so i wont need soffits.
The AV closet is actualy going to be IN a closet. I thought of it while going over electrical options. I ddint want it to be in the front of the room, and i didnt want it sticking out on the side somewhere.
Then i was thinking i could take 24" of the closet and use that for the AV stuff. I will ad a door on the other side to get at wires and stuff.
I see some guys with A LOT of stuff in there closet and not sure what it all is. Some have 2 !!
The screen i want is 120" cause my room is 15'9" wide. I saw a Black Diamond and WOW!! Dont have the cash for that but i do want a desent screen. I saw how it cuts the reflective light out so its not
flooding the room with it.
I may post some pics from other guys theater rooms to get feed back on if its duable or not.
I like the stage some guys have so im lookin to do a 4' wide one in the front, and a platform in the back in case i need it for a larg group and then any seats placed on it will help viewing over the front row.
And i re-measured the room and its 25'8 not 27. Not sure were i went wrong but oh, well.
This is the best layout i came up with, lookin for some feedback.
Media/Big Daddy's aria -(no im not big, just like the title)
This will be kind of a book shelf. I probly will up some Marvel figurines here
The AV closet will be on the left side of this pic in that back corner
Looking down the left side of the basement, stairs are just to the left
Looking at the office from the sitting or kitchen aria
The 2 Bedroom doors
Bathroom view
And Water heater and Heatpump closet (house is all electric)
If at all possible avoid all the cabinets up front. The front wall should be completely dead and we don't want boundaries to mess up speaker response and limit sub location.
Bryan
Naw, the entertainment center will be placed on the other side in the other sitting aria. Was thinking of putting one of the one of the underling unit tables below the screen. You know its about 18" tall, but its pretty long like 6 to 8 feet with the screen centered above it. I will find an example in the gallery and post it.
Wow. So they insulated all of the floor joists, but none of the exterior walls?
Yea, no outside wall insulation. A friend and I studed the walls and all. The only thing up when we bought the house was the two structural stud walls. But now the hvac and electrical guy wants me to take the insulation down to run the duct work and wires. They stated that in the past they did it for the customer but felt it took too much of their time doing this without adding it to the quote. So i gotta do it.
Its been a while since i posted, sorry. Alot has been done. Electrical, plumbing and hvac are all in, and we just finished Sheetrock on Saturday. That stuff is messy!! Dusty. The guys are muddling and tapping and going to do 3 skim coats. I didnt have the time or the skill to do it.
I did have 2 layers of Sheetrock with Green Glue in between, but i know i didnt get enough. :p I got 2 cases, not knowing that i should have picked up another 4 ! My AV guy said his last theater customer build they used 27!! Told him that i just dont have the funds to spend that kinda money on it knowing i still have AV stuff to buy. Sanding and skim coat will be done by Monday. I will prim and paint all the walls after that.
I also need some cool sconces for the theater.
Will post pics soon...
Discussion Starter · #13 · (Edited)
Ok Lots of stuff going on. Dry wall has gone up, mud and tape and they just finished Paint. The Kitchen cabinets have gone in, but im having issues with the granite counter tops. Aaaannnyyyy ho, the Theater/media room is "Milk Chocolate" Brown with white trim. Time to start buying my equipment.
And i know guys, its a Home Theater forum, but ive spent enough time and money on it, yall are gonna see all of it, not just the theater !!
Lounge/Kitchen will have a small TV seating aria
Stair entrance and window 1
Stair entrance and window 2
HVAC Closet and Electrical Pannels
Bedrooms 1 & 2
Lounge and Kitchen on right
Theater/Media Room
The 8' platform in the back
The 4' Stage in the front
Left wall (will probably put some Marvel and DC statues here :D)
AV Closet, recessed into the first storage room
I am narrowing my equipment down
Projector 1- Epson 8100 or 85UB (my AV guy wanted the Optoma HD2200 1080p HD Projector)
Onkyo SR608 7.2 Ch Receiver
Peerless Projector Mount (my AV guy suggested it. Do i need it? Its listed at $189 !!)
Dragonfly 110" High Contrast Screen
Polk Audio TSi400 Tower Spkrs (Pair)
Polk Audio CS-10 Center Speaker
Sanus Black Center Speaker Stand
Polk Audio OWM3 Surround Speaker (Pair)
Episode C-5 Series 10" 200w Sub
URC MX880 Color Remote (Retail $499)
URC MRF260 RF Module for Remote
Lutron URC Remote Switches
Binary 2160 Joules Surge/Conditioner
I would appreciate any suggestions on the equipment. Prose and cons Im trying to stay in the 5K or 6K aria.
I trust my AV guy, its just that im spending most my money trying to Finnish the entire basement so he is trying to get me the best deal out there for my price range.
· Super Moderator
Nice work, you’re brave to tackle all that taping floating and sanding.
I’d pass on that sub. Another $150 or so will get you an SVS PB10, which will go all the way down to 18 Hz. That’s almost a full octave below the one you’re looking at. Trust me, that makes a huge difference.
Discussion Starter · #17 ·
LOL no guys, Im here in Atlanta Ga. I did (i didnt want to...) get my build permitted but here we dont put styrofoam on the walls. The white stuff is a water proofing agent called Drylock. The studs are an inch off the walls. Code says at least half an inch so its all good.
Mdrake there are only 2 windows and i designed them on my layout 1 in each bedroom.
Wayne i didnt do the mud and tape, i payed the "boys" to do it.
Discussion Starter · #18 ·
Its commin together. I got the call that the carpet is all in at lowes and the final inspection is done. Bout to go and get ALLLLL my AV equipment.
Im looking at -------
Epson 8100 Projector
Discussion Starter · #20 ·
Had alot of to-do stuff on my list, but I GOT MY GEAR BBBAAAABBYYYYY !!
I picked up the speakers and projector from HHG. I hated not getting them through my AV guy, but im at the end of finishing my basement and the well is running dry. So i had to do something i havent done in 3 years. I PUT IT ON CREDIT!! My wife couldnt believe i did it, but i got everything i needed and was able to keep my cash. I im happy though cause i near got everything CHEAPER than i would have had i gotten them from Amazon. I was in and out of there and BB for the last 3 months so much that the Home theater guys in each store knew my face WELL and was ready to do a deal cause they KNEW i was gonna make a large purchase.
My av guy has to get the 2 sets of Polk Audio OWM3 Surround Speakers cause no store carried them.
Sooooo i picked up the
Epson 8100 Projector (i really wanted the 8500UB
I was gonna get a different Blue Ray player, but how could i pass up getting a PS3.
sparkymt - Thanks dude. My GC didnt want to do it at first, but after he did it and added the spindles at our request, he loved it. I opens up the landing. I came out really well thanks.
1 - 20 of 24 Posts
