1 - 20 of 41 Posts
Like the title says: my bass is floating about 1 foot above main listening/seating position - what can I do to lower it? The bass is positioned for the best response, however it's floating. Any ideas gang?
What kind of flooring do you have? Do you have more than one sub?
Have you adjusted the phase on the sub/s as I think your canceling something out.
What is the height of the room and your seated ear height?
Bryan
The room height is 8ft. The seated position of where ears fall is 3.3ft. The bass is floating at exactly 5ft.
Thanks for any help, Bryan!
I'm also gonna try switching the phase today.
Well, if it's at 5', that's 62.5% of the room height - basically the predicted 38/62% optimal. Panels over your head and/or getting the sub off the floor are potential solutions in addition to tweaking phase.
Bryan
Bryan
I just did a walk-around and found something interesting. This image I created should help! (see attached)
Bryan
Should I play with how high I bring the sub off the ground or is there an optimal height? I've been wanting to build a bass-trap/riser - but never gave it any thought since I didn't think I would need one.....man, looks like I was wrong!
In the corner with the sub is going to cause the most issues. I'd just try it on the other side of the monitor but still on the front wall. Play with location and reset the phase accordingly but I think that will help some.
As for the height, try maybe 15" off the floor.
Bryan
Bryan
Thanks Bryan - I'll give that shot this afternoon.
Discussion Starter · #13 · (Edited)
The height is purely a guess.
Bryan
I'll experiment. Since I don't have a bass trap/rise, will raising the sub have any adverse effects?
It shouldn't. It's just getting it away from another boundary. You may notice a reduction in overall output but you'll get that just getting out of the wall/wall corner.
Bryan
Discussion Starter · #15 ·
Bryan
Well, after playing with the height of the sub, I was unsuccessful at getting the bass to settle within the listening level. :(
I moved the bass to the other side of the monitor and no dice. :hissyfit:
I even brought in an "expert" (see attached) and even she was unsuccessful.
OK. Was there any improvement at all? Any change in frequency issues by either raising it or moving it?
Bryan
Discussion Starter · #17 ·
Bryan
Not a huge difference - I even tried pushing the chairs one foot forward, one foot back - nothing. But when I stood up - I could hear the bass. :(
OK. If you did all of that, then the next step is to have some thick panels on the ceiling over the seating position.
Bryan
Discussion Starter · #19 ·
Bryan
Define "thick". LOL!
Even with such a low ceiling? Craziness!
1 - 20 of 41 Posts
