I set up my system with the AVR's test tone played at volume control knob at 0db.
I put SPL meter switch weight C, slow and matched the sub volume to the other speakers. All read 76db.
I also did a graph in REW and it blended well with the mains up to 150hz.
And the bass seems a bit loud in movies when I play the movies at a lower volume, e.g. at night I play 6 db less than I normally do.. It's not bad when I play the movie loud I think because everything is so loud anyway. Maybe there is more reverb at lower volume that I can hear?
There are some trailers on a BD and they are mixed in DD stereo or 5.1 and the bass in those are really quite loud (do they mix trailers that way to get your attention)?
So does the sub volume output linearly through out the volume range of the AVR?
