1 - 7 of 7 Posts
Just checking out some of the wicked finished cabinets on the sub database here and I have a quick question regarding how to prep the sub for painting. For those of you who used butt-joints or even people that used plywood, how do you prep those areas for painting after sanding? You know, so you don't see a seam or in the case of plywood, the wood layers? I notice people putting some white/grey stuff on...what is that?
Thanks for the help. :)
Caulk and wood putty is the most common filler that most use for the corners. Are you using plywood or MDF?
1 - 7 of 7 Posts
