Time to get your guys input...
History:
We had our house built and moved in on Halloween. The house was built with the media room option over the living room and before the builder sheet rocked I was able to at least get my wiring in. The house is wired to whole house audio, and streams from the Puter downstairs. I ran Cat 6 everywhere for an intercom, and an seperate network of Cat 6 to all the media centers to the office where the router and Mac are located. So I am hardwired to the router for downloading movies to Apple TV soon.
Now that we are here, I have finished my hookups for the media, and got the Home Theater hooked up and running, and calibrated it for the present situation.
Heres where you guys come in...
Time for the pretty up, and finish out of the room to turn it from a dedicated media room to a true home theater.
Specs:
Sony HW10 Projector
Peerless mount
Elunevision 1.2 gain 120" white screen
Denon 2809ci hooked HDMI to the projector
Sony BDP350 Bluray player
Uverse
Apple TV
Samsung DVD player (for playing DVD audio discs) More on that later
Klipsch F3 mains
Klipsch C3 Center
Klipsch S3 surrounds
Klipsch 12 Sub
Room:
18'x18'x8'
4 Berkline 13174 seats in curved configuration
Rack to be determined
So next up:
Acoustics and paint
The room has an echo, and little mid range bass even with the sub and dual woofers on the towers.
The only acoustic plan for sure so far is to deaden the front wall by completley covering it will 1.5" or 2" JM814. Wedge shaped bass traps will go in the front corners floor to ceiling, and the screen will be remounted placed away from the wall a few inches to accomodate rope lights behind it.
Other than that... I am open for suggestions for decorations, and acoustic treatments. let me add right now that I know the proper thing to do would be to get someone in here to measure the acoustics and follow thier advice, but I also know what I want to hear in the room, and I dont hear it yet.
As far as decor, the front wall will be covered with black fabric, either burlap or GOM701 as will the bass traps. The side walls will get panels at the reflecting points and/or a chair rail hieght acoustic treatment all the way around the room and 2x2 panels at the reflecting points.
I am open to suggestions for color, design, acoustics, and whatever else you have.
Thanks for looking...heres the snappers...
Kirby
p.s. I think we have narrowed the walls to a brown, and I found a bargain on Speaker fabric so that is what I will use on the bass traps and screen wall...
History:
Specs:
Sony HW10 Projector
Peerless mount
Uverse
Apple TV
Klipsch F3 mains
Klipsch C3 Center
Klipsch 12 Sub
Room:
18'x18'x8'
So next up:
Acoustics and paint
Kirby
