WmAx,
Yes, your first scenario is exactly how I intend to utilize the unit. I want to manage each sub independently from my listening position to arrive at the best response each location has to offer. Once each is established, I'll then assess the system as a whole.
I have the unit on order and expect to receive this Friday; I'll spend some time this morning assessing mics.
Larry M.
Larry M.
Well, do you have more then 2 dedicated sub signals? For example, usually LFE is mono. The DCX can apply separate processing and EQ to each input and output separately. So, if you start with a single mono LFE input, then you patch it to all 6 outputs, you can then apply custom EQ/processing/xover to each output in an isolated fashion. Or you can derive the the bass signal from stereo inputs and mix to mono and then patch to the channel outputs desired.
Now, of course, if you want to send full range input for each channel of a surround system, then you need 2 x DCX2496 devices.
-Chris
