1 - 4 of 4 Posts
I want to equalize the monaural sound system of a school auditorium.
Does the Behringer DEQ2496 (a current model) work well with REW and would it be suitable for this?
Thank you.
DEQ2496 is excellent for it.
It has both graphic equalizer 1/3 Oct (31 slides) and 10 band parametric equalizer that can work in conjunction.
For Mono PA you can use one channel only (the DEQ2496 is stereo with two independent channels)
It has also anti feedback filter
I am using the DEQ2496 for room correction of my listening room by setting the filters manually based on REW measurements.
Issi geier
I've been reading that people have power-supply-related heat and RFI issues with it. Have you had any problems?
No, I do not have any heat or RFI issue.
It is only happened if you have it in a closed rack above the heat of a power amplifier and poor ventilation.
Issi
1 - 4 of 4 Posts
