1 - 3 of 3 Posts
I just wanted to calibrate my "soundcard" for measuring my room, when I found a strange, smooth, but not flat curve.
I use a M-Audio Delta 1010LT - internal PCI soundcard and usually connect it to my Behringer EURORACK UB1204FX -"PRO" to use microphones for recording and playback on different speakers.
I compared the calibration measurement of when I connect the ports of the soundcard directly, to the measurement through the different channels of the Behringer and I found a normal "flat" curve on the direct connection and different curves on each channel of my Behringer EURORACK.
Note: The 3-band EQ settings on all channels were snapped into "flat" position but it seems like just a slight touch on the knobs changes this EQ-setting, while they are still snapped as flat.
The graphics in the attachment show the calibration measurement of the soundcard directly an those of the 6 different channels of the Behringer. As output I used the "pre"-fader AUX 1.
Has anybody else experienced that with a Behringer or other mixing console?
Super Moderator
Hey roomeqtester,
First, welcome to the Forum!
Obviously it appears that the center detent settings for the EQ knobs are not the true zero-gain positions. However, it doesn’t seem unreasonable to expect that the engineering controls might not be that tight for a < $200 mixer? Nevertheless, judging from your graphs the deviations are less than 1 dB in every case – not enough to make any difference for room measurements.
Hu? Thought I posted a reply a few days ago. Maybe did not click on "post.
so. I said somethng like:
Hey Wayne,
thanks for your thoughts. I have to admit you're right. That is not such a big deviation, especially compared to all those scary dips and peaks of the following room measurement.
However, as I used to use this mixer's preamps for recording it is good to now how the EQ settings can differ, since 1dB can make a difference.
Nevertheless, let me say this REW is a great piece of software and "hello" to everybody here, thank you for all the valueable information you are putting in here. I was reading a lot now here for a few month before this first post of mine.
Florian
1 - 3 of 3 Posts
