1 - 11 of 11 Posts
Hi there,
I want to buy an hpf this week but am torn between the two. I have also looked at the Behringer DCX2496. I am looking for some advice. Would the DCX2496 replace my current BFD so that I can just use one device. It is more expensive than the two others mentioned but is it worth the extra and save me with cabling.
Also I need a hpf set at 12hz with a 4th order. I have two FI Q18 slot ported subs tuned to 13.5hz in 311 litres enclosures each. I want to run to REW sweeps to see what I can get out of them and my current setup exceeds max excurson at 11.5hz at full power. So I want to get a hpf just to protect them for this reason. Also to be able to play bassotronics at reference if I choose.
cheers
Graham
Hi there,
cheers
Graham
I know of no device that delivers a true 12hz 4th order filter. Even the Reckhorn is limited by it's roll-off. Furthermore there is no need to filter that low IMO.
The DCX2496 is one of the best loudspeaker management devices out there, but it won't filter below 20hz.
The main problem is when I play bassotronics which I do quite alot, more for fun really, I get alot of excursion even at -25db volume on the onkyo and I know that I would not be able to run anywhere near reference without a hpf. I can play a 15hz or even a 12.5hz tone at extreme levels but at 10 without a hpf at full power I am at 58mm of excursion. I am guessing that with the Q's there are 27mm of one way excursion so that adds up to 54mm so am I correct in saying what I am only over by 4mm full excursion.
Winisd is showing me that at full power I am at 108db at 10hz for one sub at full power. Obviously I know that the EP4000 probably isnt running 1250 watts into 2ohms in real life but I don't know what the true wattage rms into 2 ohms the EP4000 will run. So if it is only giving say 8-900 watts rms true output into 2 ohms I would probably be at about 45mm excursion.
I hope this makes sense.
cheers
Graham
The minimum the DCX will allow u to set a hpf is @20 hz, which will give u -6db @10 hz ....could be what ur looking for.
Remember that there's soo much more it can do...a truly powerful device to have in any system.
Graham, WinISD is only showing you a ball park figure, it doesn't take into account the effects of power compression or port compression. Then there's also the issue of voice coil temerature rise.
Hi there,
cheers
Graham
As others have mentioned 12hz is not a usual freq for filters for audio use. Can you solder? If so there are a couple of DIY options that will do the filter at least and you could just use the BFD for EQ.
Discussion Starter · #9 · (Edited)
Ricci,
I take it I connect the bfd before the mic2200 and then the EP4000. I doubt very much that I would get away with just one band of EQ but you never know. Is there much chance of getting any hum from the Mic2200 that you know.
I guess also that the hpf is trial and error to a certain extent.
One question, In Winisd when you set the hpf, is a fourth order the same as 24db and second order the same as 12db?
cheers
Graham
Super Moderator
Not sure what do you mean by that? "Roll off" is what a HPF is supposed to do, isn't it? :huh:
Your cheapest option will be the MIC2200. You can daisy-chain the two channels to get your 4th order @ 12 Hz (assuming its even flat down to that point).
That's correct.
1 - 11 of 11 Posts
