1 - 4 of 4 Posts
I have been very pleased with my used Benq 8700, it has provided a very satisfying picture. I started to notice a couple of weeks ago that I have to fiddle with the controls to try and get a good picture and lately I can’t get close to what it once was.
It seems too dark and if I raise the brightness control or contrast it does get brighter but just seems to washout. Is this a sign the bulb is at the end of its life or some other internal problem? I have no idea the true number of hours on the bulb as it was used; I have put about 700 hours on it myself.
I don’t want to invest in a $300.00 bulb for a used projector that I only paid $350.00 for to begin with...so what do you all think?
Big thanks
dusty
It sounds like an old bulb to me. You should be able to check your bulb hours in the menu - information tab. At this point you can choose to get a bulb or a new projector - whichever you prefer.
The bulb hours were reset when I got the projector, but the seller said that it was not new and thought it had about 800-1000 hours on it. He could not confirm the exact number of hours.
THANKS
dusty
A bulb at 1800 hours is certainly approaching the point where it will dim significantly (especially an older bulb). That definitely sounds like the cause of your issue.
1 - 4 of 4 Posts
