I set the speakers as small, otherwise subwoofer wont sound, and the crossover set at 80hz. I didnt run the audissey since it is a 2.1 setupyoda13 said:
I set the speakers as small, otherwise subwoofer wont sound, and the crossover set at 80hz. I didnt run the audissey since it is a 2.1 setupyoda13 said:Agreed with almost everything you said, but I'm having a hard time seeing the "big difference" between the 709 clipping and the added XPA-2 starting to distort the Polks.
I think that the "full" sound that the OP is looking for is somewhere between the sub's crossover (maybe the mains are set to "large") and possibly Audyssey's setup.
Having said that, if the OP wants an amp, then by all means do it. Amps are cool anyway.:bigsmile:
I'm kind of lost here, sorry, may you illustrate me about "high amount of gain" and AVR/SSP?
I honestly think a number of folks are actually agreeing with you about questioning just how much benefit there would be to adding an amplifier.You said it yourself "they (the speaker) dont sound as good as they should" so Im taking a more direct approach....btw you guys are beating the amp issue to death.....
My suggestion, having auditioned this POLK series for my neighbor who was interested and knows I do HT install work is this....replace the tweeters with these....
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1016
this will improve your sound quality very nicely at much less cost than a new amp :T ....
First of all, thanks so much for your opinion and explanations. I really tought the idea to add an amplifier will be welcome by all of this forum. To be honest, This only has brought me more questions than answers.Jungle Jack said:I honestly think a number of folks are actually agreeing with you about questioning just how much benefit there would be to adding an amplifier.
Just level match the Emotiva compared to any other Power Amplifiers or even the 709. The XPA-2 is far more powerful than the 709 so there is no question it can provide more headroom, but it really comes down to whether this added power is really needed.
Hey, can you provide a new link, if you still exist? TTY TYYou said it yourself "they (the speaker) dont sound as good as they should" so Im taking a more direct approach....btw you guys are beating the amp issue to death.....
