1 - 3 of 3 Posts
I have family of a friend looking to build their first proper home theater. Suppose their budget is right around $4-6k; which projectors are likely to offer them their best bang-for-buck ratio? A few years ago JVC had some remarkable projectors in that price range, but I haven't kept up since 2010. No UHD or 3D stuff is needed; just a good projector and screen for $4k (or less). Also, it will be important that the projector offer solid calibration controls, as I'll be giving these folks a free calibration. Also also, just in case they prefer to keep their projector price down to, say, $2-3k in order to leave more money for the audio, which projector would serve best in that lower range?
Thanks much in advance for any advice,
David
On the lower end, I'd recommend the same as I did for Leonard - Epson 5030 and an Elite Screen with the Cinegrey material.
I haven't kept up that much with the $4-5K projectors to have any confidence in making a recommendation.
Thanks, mechman. That was my hunch--either the Sony HW40ES or the Epson 5030. So is there nothing substantially better than those (PQ-wise) in the $3-4k range? From what I've read, it looks like the next big jump in PQ comes in somewhere around $10k, which I'm quite sure they cannot afford.
Yours,
David
1 - 3 of 3 Posts
