1 - 3 of 3 Posts
what the best fabric option to use for diy acoustic panels an basstraps with images from
Design Fabric Printing
for my diy acoustic panels an basstraps
or from Contrado: Buy or Sell Artist Designs | Print on Demand
www.contrado.com
Printing On Florence Net Fabric. Custom Digital Print Net Fabric
Digital Net fabric printing, no minimum orders, customize online for personalized textiles straight to your door. Express Delivery.
www.contrado.com
www.contrado.com
or the default
www.contrado.com
Custom Speaker Fabric Printing. On Demand Digital Printing
Custom Speaker fabric designed by you. Order your patterns as test prints or get a swatch pack with all our printed samples. Express delivery.
www.contrado.com
www.contrado.com
would either from this site work
my new acoustic tiles an traps are to be either four custom 6in by 36in by 6ft frame-less traps two parallel to either side of the ht room
the plan is to get four six packs of roxul 80 an stack in a row of three deep by three tall after trimming them down to 2ft by 3ft an wrap the 6in thick perimeter in burlap an use duct butter on the burlap an roxul i think that will make it sturdy an rigid then wrap the whole with acoustic fabric
i also plan to some 60 x 10 x 3 mm Neodymium Bar Magnets stitched into the burlap in the back of the acoustic panels so as to adhere the panels to some painted metal strips on the wall which hopeful will allow for ease of placement an remove
would anchoring to just sheet rock with expander screws the total weight would be about 57 pounds
using 6 Neodymium Bar Magnets per tiles should give 72 pounds of pull does anyopne think this will work
or is this a **** shoot
1 - 3 of 3 Posts
