1 - 5 of 5 Posts
DIY Screen will be 2.39:1 and I will be sitting at 13' .
I have looked at some calculators ,but they seem to be all over the place ?
Is there 1 that is more reputable than the others ??
thanks !
You can take most with a grain of salt anyway since they are only approximations. A lot depends on your own eyesight and its acuity. My favorite is the CarltonBale chart which shows plots for the most common systems including UHD. The fact that you are going for a 2.39:1 display will change the figures slightly (depending on how you get there), but not significantly.
http://carltonbale.com/1080p-does-matter/
Try this one at Projector Central. It gives a nice range of seating distances, and you can get accurate results for your make and model of projector, and it is one of the more popular ones.
1 - 5 of 5 Posts
